I have a Kenmore Bottom Freezer Refrigerator. There is power at the plug but no lights on control and doesn't run or do anything. Control board maybe? Thanks
I would use a meter to check for voltage to the control board AP4366538, voltage in and nothing out generally is a bad board. You can look at the board, something burnt on the board confirms failure.
Thanks, Is this board located in the refrigerator where the tempature adjustments are? On some brands the main board located on the back of them. Not this one. Thanks
