The timer will only advance when used for the 60 Minute timer setting, Perm Press and Auto Dry will stay on continuously. I just replaced the timer itself as well as the cycling thermostat and the problem still exists. I did vacuum the bottom of the unit out as is was pretty bad. I also blew out the vent, cleaned out the lint trap. Any Idea what might be causing this problem??? Thanks for your comments/ suggestions.
