draleigh53
#1 Posted : Thursday, January 22, 2009 8:03:03 AM(UTC)
draleigh53
Hi All
I live in Michigan,recently had a power outages went to reset-up my microwave , everthing working (except won't heat) is there a service code that I can put in and reset just in case it was knocked out by the outage?
magician59
#2 Posted : Thursday, January 22, 2009 11:26:10 AM(UTC)
magician59
Electronic control boards are highly vulnerable to power surges. The problem could be in the board, even though everything else seems to work. You need to be able to isolate the trouble to either the low voltage, or the high voltage side of the oven. This can be accomplished with a "live voltage" check, but is extremely dangerous, if you're not competent.
