Hi all 1st time post. I replaced the heating eliment and check the power from the wall and still have no heat. Can some one please help me figure oout what to check fo. I do have a tester and some knowlage on checking AC. Many thanks
On the top left side of the element housing is the thermal fuse. It is the size of a dime. Take the two wires off of it and check and see if you get an ohm reading. If not replace it. Of course you will unplug the dryer, when you do this. Tom
