mattschmidt69
#1 Posted : Wednesday, January 21, 2009 8:00:51 AM(UTC)
mattschmidt69
Hi I am new here so please be nice. Anyway I have this dryer that I can not get to work right. The heating element will come on but only when I put a jumper wire from the high-limit t-stat to the metal vent pipe. Then it comes on fine powers right up. The timer is testing out to be open when it should be and closed when it should be as well. Allthe other fues and t-stat are ohming out like the should as the element does as well. But the element is only getting 120v, not the 220v it needs to work. But I also noticed the the element box is black on only half of it. Please help ASAP!!!
Thank you for any help!!!
#2 Posted : Wednesday, January 21, 2009 8:20:48 AM(UTC)
Do not understand why you would do this.
The heating element should not be grounded, it should be wired between L1 and L2 not Neutral/ground. You are asking for an arc and spark. Perhaps that is your problem a grounded element.
Open it up and make sure it has not warped and is touching ground
The element will heat on 120 just not get as hot
How do you know it is only getting 120.
Did you measure across the contacts going to the element. Note you do not measure to ground.
Also have you checked your power at the plug. Often half the line can drop out without actually tripping the breaker so you end up with only 120 at the machine. Depending which side drops the motor will run but you will have no heat.
kayakcrzy
#3 Posted : Wednesday, January 21, 2009 4:18:18 PM(UTC)
kayakcrzy
It is under a year old, call a service man. But you might want to flip the dryer breaker off and on a few times, and see if it works. Also how about checking the power where the plug goes into the dryer. You should get 240 volts from the far right terminal to the far left terminal. Tom ApplianceEducator.com
mattschmidt69
#4 Posted : Wednesday, January 21, 2009 5:34:10 PM(UTC)
mattschmidt69
I have not tried to check the house side of things, but thats a very good idea. Also I was not trying to short out the unit by placing the jumper from the t-stat to the vent...the thing touched it by rare chance and got itself turned on. But that really made no sense to me. There is nothing that is visable that is wrong with the element and it also ohms out. And the 3 position rotary switch was change out recentaly and also the thermo fuse was tested and ohmed out. All the parts are making the right test, when tested but yet we have no heat and I really think this maybe a house issue because it was for rent awhile and he had some problem where the heat shut down and lose power and then "it just came back on a couple days later", maybe these two problems are related. I will check this out as well as anything esle anyone can offer up for me to look at in the morning, so please respond Tonight! THANKS A TONNNN!!!
#5 Posted : Wednesday, January 21, 2009 6:32:20 PM(UTC)
You may have found it
"he had some problem where the heat shut down and lose power and then "it just came back on a couple days later"
May not even be a problem in the house, this could be an electrical feed problem.
If you have an electrical stove turn that on as it's elements also run on 240 volts.
