tk314
#1 Posted : Sunday, November 11, 2007 4:46:46 AM(UTC)
tk314
Hi! Hope you can help me out here. We have the GE JVM2070CH01 over the range microwave and the three buttons for the Vent/Boost/Light control are not working anymore. I found an exploded diagram for the microwave on GE's appliance site and the module that I believe needs to be replaced or probably reseated is Item #17 (P/N WB27X10725). I think that part is probably a pc assy with the switches on it and my guess is that it has broken loose from its mounting position. But, I can't figure out how to get to the thing to see what needs to be done. Can anyone explain to me how to gain access to the switch module? :confused:
Thanks!
Tom
tk314
#2 Posted : Sunday, November 11, 2007 6:31:03 AM(UTC)
tk314
Aha! I figured it out and sure nuff, one of the switch module mounting ears is broken off. This should be fun to try to fix... :eek:
conordh
#3 Posted : Wednesday, December 15, 2010 5:34:34 AM(UTC)
conordh
I know it's been a few years, but I'm having the exact same problem. Did you need to buy a new key module? If not how did you fix it?
