pgtek2001
#1 Posted : 13 years ago
pgtek2001
Hi All
I have this problem.
it overflow in my freezer compartment
the water does not stop flowing to my icemaker
what could be the problem
#2 Posted : 13 years ago
Most likely the problem is a bad water inlet valve on the back of the refrigerator.
- The water inlet valve Part number: AP3192626
pgtek2001
#3 Posted : 13 years ago
pgtek2001
Hi Gene
Thanks for the replied.
I did a test and unplug the refrigirator and turn on water no leak
plug back fridge and it took the water and stop.
then ice drop in basket then it took water and did not stop
could it be that part you listed :D
#4 Posted : 13 years ago
Very likely.
pgtek2001
#5 Posted : 13 years ago
pgtek2001
Thanks :D a million your the man:cool:
#6 Posted : 13 years ago
pgtek2001
#7 Posted : 13 years ago
pgtek2001
Hi Gene
Thanks alot.
I order part and install it and works like a charm
Thanks a million :D
#8 Posted : 13 years ago
You are welcome. I'm glad it's up and running. Thank you for the feedback.
