griggmi
#1 Posted : Saturday, November 10, 2007 1:53:12 PM(UTC)
griggmi
After a power outage, the oven controls do not light up and are not touch sensitive as they should be. The back panel is dark, and the oven will not work.
The stove top is glass touch sensitive also, but all the surface controls for the stovetop work properly.
Previously after a power outage, the oven controls stay dark for about 24 hours, and re-light on their own, but not this time.
Tried unplugging the stove for 2 hours like user manual states, and this did not work.
#2 Posted : Saturday, November 10, 2007 6:43:47 PM(UTC)
Hi griggmi
Most likely the problem with your oven is a bad control board.
- The part number for the new control board AP3858099
Good luck.
Oven control problems (Oven Repair (including Ranges and Cooktops))
by Eagar1 8/5/2012 12:31:05 PM(UTC)
Kitchen Aid Electric Range, Oven Control Problem (Oven Repair (including Ranges and Cooktops))
by pza 12/25/2011 6:26:16 PM(UTC)
oven control problem (Oven Repair (including Ranges and Cooktops))
by icandoitto 2/16/2011 9:44:03 AM(UTC)
Oven control problem (Oven Repair (including Ranges and Cooktops))
by PatinKY 1/3/2011 6:59:58 AM(UTC)
oven control problem please help ASAP (Oven Repair (including Ranges and Cooktops))
by renessabbd 12/22/2010 10:32:24 AM(UTC)
Oven control problem - HELP!! (Oven Repair (including Ranges and Cooktops))
by razorblade 12/30/2008 2:04:20 PM(UTC)
Admiral Electric Oven Control Problem (Oven Repair (including Ranges and Cooktops))
by stephenm38 11/8/2008 4:24:22 PM(UTC)
