t38263
#1 Posted : Monday, January 19, 2009 2:36:49 PM(UTC)
t38263
due to a problem with water not getting to the ice maker, i changed out the dual water valve and fixed my problem. however, 2 weeks later my water in the door feature stopped working. i changed my water filter today and that did not solve the problem. i think the dual water valve may be defective.
#2 Posted : Tuesday, January 20, 2009 1:06:57 PM(UTC)
Check if there is 120VAC to the water valve solenoid (blue) while the dispenser calls for water. Post the results.
