JoyJerm
#1 Posted : Monday, January 19, 2009 9:30:48 AM(UTC)
JoyJerm
My dryer is just like an oven that will not cook food. I put the clothes in and they are still wet. I assumed that it was the heating element. Before I order from the site I wanted to have an idea that I was ordering the right thing. So am I right with my guess?
#2 Posted : Monday, January 19, 2009 9:48:52 AM(UTC)
Is IEX300RQ1 correct or should it be IEX3000RQ1?
JoyJerm
#3 Posted : Monday, January 19, 2009 9:18:37 PM(UTC)
JoyJerm
Yes, you were correct the model number is IEX3000RQ1
#4 Posted : Tuesday, January 20, 2009 1:45:47 AM(UTC)
Here is your parts breakdown
Model IEX3000RQ1
Here is your wiring diagram
https://www.servicematters.com/d...0Sheet%20-%208576793.pdf
The most common causes for no heat are the heater or the thermal cutoff (Item 6 in Section 1).
The best way to check is with a meter.
If you do not have one I would suggest you purchase one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
If you do not have a meter and do not want to purchase one, pull the heater and check it visually for a break.
The cut off can be checked by shorting the wires together, taping them up so they cannot touch the frame and giving it a try. If it fixes the problem replace it ASAP as this is a safety device.
If it is the thermal cutoff be sure to clean/check your vent system.
Also the lint filter. If you use liquid fabric softener it can coat the screen greatly reducing air flow.
Remember to always unplug or remove power from the unit when working on it.
240 Volts can kill!!!
