bobar
#1 Posted : Saturday, November 10, 2007 9:40:33 AM(UTC)
bobar
Nothing gets hot. The stove top indicator lights come on but none get hot. Also, neither oven gets hot and the indicator light for either oven does not come on unless a stovetop burner is also on
Also-Model Number is a RE-629VK
okbobcats
#2 Posted : Saturday, November 10, 2007 6:50:31 PM(UTC)
okbobcats
I would check the in coming volts.
#3 Posted : Saturday, November 10, 2007 6:50:40 PM(UTC)
Hi bobar
The first thing I would check is the circuit breaker for the range.
It suppose to be a double breaker which providing 120V through each breaker and 240V total.
If one of the breakers is off or broken, then only 120V is coming to the range which is enough for the indicator lights, but is not enough for any of the heating elements. They need 240V.
Good luck.
