My dryer works right off the bat, works great, at some point the flame goes out but then wont re-light. If I give it a few minutes and turn it on again it then will light. This thing is old but I know how to fix most things on it. I like that. Hate to replace with one I don't know. Has a new ceramic starter and belt. And just greased the drum. All good but not enough heat.
I did notice that it did try to re-light the ceramic was glowing but the flame did not come on.
Mark
replace the gas valve coils
I want to thank you for your fast reply, I read about the other guy with the same symptoms, and it seemed to work for him. So I went to find the coils I need under my model number and none are listed could my dryer not be using coils?
