utahskierdave
#1 Posted : Sunday, January 18, 2009 10:40:58 AM(UTC)
utahskierdave
My 4 year old frigidaire dishwasher won't run....I had this issue before and it seemed that unplugging then plugging it back in did the trick. Now, when I unplug it the "heated dry" and "hi-temp wash" lights flash, indicating a power failure. I press "start/cancel" per the service data sheet then I can select my wash cycle. When I press start again nothing happens. The wash cycle light goes out and then, nothing. Any thoughts? Thanks in advance for your help.
utahskierdave
#2 Posted : Thursday, February 5, 2009 7:16:42 PM(UTC)
utahskierdave
Is there anyone on this board who might be able to help me??? Please?
#3 Posted : Friday, February 6, 2009 6:34:43 PM(UTC)
The first thing I would do is check if the door switches are properly engaged when the door is latched. The model number you posted is incomplete.
