papalyons
#1 Posted : Thursday, November 3, 2011 12:11:27 PM(UTC)
papalyons
Dishwasher will not run except when pushing cancel/drain. It then runs, but does not drain. Pushing any other cycle button, the lights light, but nothing happens. It filled with water when the cancel/drain was pressed
#2 Posted : Thursday, November 3, 2011 1:20:00 PM(UTC)
Remove the bottom access panel and check if the motor runs while the control calls for wash or drain.
Post the results.
