Brand is GE Model: GSS25WGTI CC
I moved my refrigerator and it will not cool now. I did not tip it. I had to remove the doors to get it out the door. I did clean it by blowing air through it. Compressor is humming... It is warm but not hot. Condenser fan is working. Evaporator fan is running. Every time I open the door the evaporator fan is on. I feel the air in the freezer (not cold) but I do not feel any air in the refrigerator from the evaporator fan. The freezer will not cool below 60 It worked great before I moved it.
Thanks in advance!!!
If the condenser coils are not warm, your compressor is not running. If there is any frost on the evaporator coils, it developed a refrigerant leak.
