jwmark
#1 Posted : Tuesday, November 1, 2011 6:24:15 AM(UTC)
jwmark
The bearings are bad on the rear outer tub assembly. How do you remove the inner tub assembly to inspect the shaft for damage? How do you remove the rear outer tub assemble to replace it? Thank you!
sidfink43
#2 Posted : Thursday, November 3, 2011 5:26:06 PM(UTC)
sidfink43
Here is a link to the service manual, but given the cost of this repair and the fact that is is not a particularly outstanding example of a good washing machine I suggest you consider replacing it.
http://www.emaservicetips.com/p..._TumbleActionWashers.pdf
jwmark
#3 Posted : Thursday, November 3, 2011 6:12:35 PM(UTC)
jwmark
Thank you!
