gyomig
#1 Posted : Friday, January 16, 2009 11:41:24 AM(UTC)
gyomig
Hi, I have cleaned the coil. I have noticed that there is a noise missing it used to come on and off. There is no frost on the back. The freezer won't keep ice cream .
libertyappl
#2 Posted : Friday, January 16, 2009 12:03:43 PM(UTC)
libertyappl
Are the compressor and both fans running, one near the compressor and one in the freezer?
Nat
gyomig
#3 Posted : Saturday, January 17, 2009 6:33:51 AM(UTC)
gyomig
Hello when I looked again there is frost on the back of the freezer .I saw one fan near the coils and it was running .Don't know where the other one is but I will look
libertyappl
#4 Posted : Saturday, January 17, 2009 6:57:03 AM(UTC)
libertyappl
If there is a lot of frost on the back of the freezer, remove the lower rear panel in the freezer and see if there is a lot of ice. If so and you have an ohm meter check the defrost thermostat (little thing about the size of a quarter and 1/2 " or so thick with two wires) located near the top of the evaporator coils. If it does not have continuity replace that part with this Part Details - FRIGIDAIRE Thermostat - defrost, part number: 5303918214. If it does have continuity go to the refrigerator side and open the control panel up and locate this part Part Details - FRIGIDAIRE Adaptive defrost control board, part number: 240554502 (defrost control) and replace that part.
Let me know if this helps or if you need any thing else.
Nat
