dirtwheels
#1 Posted : Sunday, October 30, 2011 1:23:24 PM(UTC)
dirtwheels
OK, maybe not!! But it's a persistent water slinger and I'm 2 shots down and it's winning so far. Any tech's have the magic bullet to put this water slinger back in it's place?
Appliance – Fisher Paykel GWL11US
Problem – During spin/rinse cycle water is slung out of the basket, drips down the sides & front of machine. Upon opening lid water is observed on the top of the lid and all exposed surfaces. Recirculate pump appears to run at wrong times and baskets spin speed propels water outward.
Solution 1 – Considered the re-circulate pump outlet may be too high tried to feed an additional 1/2” or so downward from original position on the right hand side of the basket. No improvement observed.
Solution 2 – Replaced control board based on advice from appliance repairman. No improvement observed.
Any ideas/solutions?
dirtwheels
#2 Posted : Wednesday, November 2, 2011 5:35:10 PM(UTC)
dirtwheels
No ideas???
dirtwheels
#3 Posted : Thursday, November 3, 2011 3:48:19 PM(UTC)
dirtwheels
Solution 3 - Remove and inspect diverter valve, find remains of safety pin holding the diverter valve open. Remove safety pin, open and inspect diverter valve, reassemble valve and machine. Test, NO MORE WATER SLINGING GWL11.
Make rule banning safety pins in washing machine!
Fire Alarm guy wins!
Guest
#4 Posted : Sunday, December 19, 2021 11:15:58 AM(UTC)
Guest
Rank: Guest
United States
How expensive is a repairmans visit ? I have a F. P. Top Loading Washer that is banging all over itself. We tried all the suggested solutions, but nothing works. Any help would be deply appreciated as the misses hates the laundromat.
