greg anderson
#1 Posted : Friday, January 16, 2009 5:10:20 PM(UTC)
greg anderson
We Have A Leak On The Floor Under The Dishwasher And By Looking On The Parts Website It Appears To Be The Inlet Water Valve. Any Ideas How To Be Sure And If This Is Replaced Is There Also Something Else That Should Be Replaced?
#2 Posted : Saturday, January 17, 2009 1:08:04 AM(UTC)
Get a small mirror and a flashlight and locate the leak.
Dry everything off and through sight/feel determine where the actual leak is, sometimes a leak can be higher up and it is just dripping from a certain part.
Could be the valve itself (replace it) OR the input line (may just need tightening) OR the output (may need a new clamp).
Also could be coming from the overfill float assembly.
Check the fill level usually machines fill to just below the heating element.
Remove the float cover and clean/check it.
Sometimes crud will build up in this area and siphon out some water.
Leak will be a few drops and only when there is water in the tub.
PS You have a duplicate post. Please delete it if you can as it will just confuse things.
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
GE Dishwasher GDF620HMJ2ES (Dishwasher Repair)
by lou@officenerd.com 1/14/2024 3:32:20 PM(UTC)
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino 12/7/2023 9:15:11 AM(UTC)
GE Dishwasher Model GDT655SSJ2SS (Dishwasher Repair)
by Dan Jones 11/16/2023 11:33:43 AM(UTC)
GDF610PMJ5ES (GE Dishwasher) - No Power to LED Display (Dishwasher Repair)
by txwildcard 6/7/2023 2:40:51 PM(UTC)
GE dishwasher GDT580SSF5SS water doesn't get hot and dishes are not drying (Dishwasher Repair)
by jmbuffy 5/15/2023 4:45:57 PM(UTC)
GE Dishwasher Loads water but never agitates to clean dishes (Dishwasher Repair)
by Guest 4/19/2023 6:38:21 AM(UTC)
GE Dishwasher, Model: GDF530PGM0WW (Dishwasher Repair)
by Guest 4/12/2023 12:06:40 PM(UTC)
GE Dishwasher GSD900D-02 Door Gasket Gap (Dishwasher Repair)
by DJW000 2/5/2023 10:05:34 AM(UTC)
GE Dishwasher dead UI board (Dishwasher Repair)
by Guest 1/26/2023 9:44:03 PM(UTC)
GE dishwasher - general query about a ball at the back in the tube (Dishwasher Repair)
by delboy1881 7/27/2022 7:49:15 AM(UTC)
GE Dishwasher beeps every 10 seconds (Dishwasher Repair)
by bethH 7/12/2022 3:03:53 AM(UTC)
Ge dishwasher seal replacement (Dishwasher Repair)
by Guest 4/21/2022 5:34:16 AM(UTC)
GE Dishwasher - No Power - Replaced Control Board, Wiring Harnes, and UI Board (Dishwasher Repair)
by aervin 4/19/2022 7:32:28 AM(UTC)
GE dishwasher not filling and other problems (Dishwasher Repair)
by Guest 4/14/2022 3:40:35 PM(UTC)
