Martie
#1 Posted : Friday, January 16, 2009 11:22:36 AM(UTC)
Martie
I just had my drain hose replaced on my Kitchen Aid dishwasher because the old hose had sprung a leak. I had called the appliance store (in house repair) where I bought it and they told me it was a plumbing problem and to call a plumber. The plumber replaced the hose. Now, the water does not drain well out of the washer. There is one inch of water covering the entire floor of the washer (not just the drain area). I called the appliance store for their opinion and they said that the plumber probably did not use Kitchen Aid drain hose. They said Kitchen Aid washers have to have a Kitchen Aid drain hose. So I called the plumber. He used a universal hose. He has never heard that Kitchen Aid washers have to have Kitchen Aid hoses. Who is right? I already have $264 sunk into this project. Another $264 would buy me a brand new dishwasher instead of two hoses!
Thanks!
libertyappl
#2 Posted : Friday, January 16, 2009 12:10:27 PM(UTC)
libertyappl
$264 to replace a drain hose??????????????????
It's probably the plunbers fault if he didn't put in a drain loop you will have that problem.
On another note, Kitchen Aide is made by Whirlpool so most technicians would say it's a Whirlpool part, I think it should have been repaired by the appliance store and not a plumber.
Post your model number please. I'll look up the part for you. Most of those drain hoses are less than $40.
Nat
Martie
#3 Posted : Saturday, January 17, 2009 7:04:23 AM(UTC)
Martie
Thanks for responding. What is the drain loop you mentioned in your post that the plumber might not have done when he installed the hose?
My model # is KUDI01TJ. The #8269905 is also mentioned.
#4 Posted : Saturday, January 17, 2009 10:03:18 AM(UTC)
Here is your install instructions
http://shared.whirlpoolc...ctions%20-%208524480.pdf
Basically a loop just means the hose should be about 6 inches higher than where it drains into the under sink drain or a garbage disposal. This prevents it from siphoning water back out of the drain when the pump shuts off.
I far as having to use a Kitchenaide hose, I think that is a load of crap.
If the hose is long enough and seals, it should do the job.
Martie
#5 Posted : Saturday, January 17, 2009 11:31:48 AM(UTC)
Martie
I'm glad you think that the brand of hose is not the problem here.
The dishwasher is not right next to the sink. The cabinets are in a U shape and the sink is at the bottom of the U with the dishwasher under the cabinets on the side of the U. The drain hose goes down into the basement and then crosses over under the floor to come up into the cabinet under the sink and connects into the garbage disposal. The hose comes up to the disposal from the floor below but is never higher than the opening. Is that the problem? Should it be raised above that disposal opening somehow before it connects with it? I looked at the manual and there is no "air gap" either on top of my sink. We have had the dishwasher in this location with this setup for 5 years with no back up problems. I did notice that the plumber put a metal clamp on the floor joist in the basement so that the hose doesn't hang as it crosses over to go back up to the cabinet. It is held close against the wooden floor joists. Before it just hung loose. Could this be the problem with the water not draining? Any ideas? Thanks for any advise you can give me!
#6 Posted : Saturday, January 17, 2009 4:21:31 PM(UTC)
Yes it should. Often it is hung from the cabinet top.
I would check that the clamp the plumber used is not restricting the flow at that point.
Also you do not want any sharp bends in the drain line.
Asko D5894 - drain hose removal (Dishwasher Repair)
by Guest 6/17/2023 11:19:55 PM(UTC)
Flap inside on drain hose (Dishwasher Repair)
by cralx2k 8/12/2019 10:38:28 AM(UTC)
Extend dishwasher drain hose for Whirlpool dishwasher (Dishwasher Repair)
by skunk_ape 5/9/2019 3:26:27 PM(UTC)
slow drain hose collapsed (Washer Repair)
by Icart7dancers 6/28/2015 2:59:16 PM(UTC)
simple drain hose issue (Dishwasher Repair)
by tooscoops 1/8/2015 6:05:59 AM(UTC)
Frigidaire Affinity - cleaned drain hose/coin catch - no operation (Washer Repair)
by Joe68hurst 6/29/2014 3:59:41 PM(UTC)
where will i find drain hose (Refrigerator & Freezer Repair)
by dirtpusher 3/10/2014 6:24:08 PM(UTC)
check valve in drain hose? (Washer Repair)
by eschutt 7/15/2013 4:49:38 AM(UTC)
LENGTH OF DRAIN HOSE (whirlpool) (Washer Repair)
by cisko1624 7/12/2013 5:33:30 PM(UTC)
Fridgidaire washer drain hose question (Washer Repair)
by eschutt 7/11/2013 5:11:14 AM(UTC)
3 connections to LG dishwasher drain hose (Dishwasher Repair)
by powerscott 6/15/2013 2:52:25 PM(UTC)
Replacing drain hose (Washer Repair)
by Gloria Hoerr 8/27/2012 9:24:37 PM(UTC)
Drain hose won't fit in machine (Washer Repair)
by LordArkana 7/7/2012 5:07:12 AM(UTC)
Drain hose question? (Dishwasher Repair)
by chubbard 5/5/2012 6:34:57 AM(UTC)
drain hose extension coupling (Washer Repair)
by jslbmiller@bellsouth.net 1/10/2012 1:01:16 PM(UTC)
