AppliancePartsPros.com
Appliance Repair Help
Microwave Repair
ge monogram counts down and lights work but doesn't run
My built-in Ge Monogram al of a sudden stopped working. The timer counts down and all the lights etc. work but the microwave doesn't come on or cook. Any ideas?
Groups ready for retrieval: Moderators
Hello. Check the door switches. If they are bad, they can cause the microwave to do this. If you need more help, please provide your model number. Thanks. Model Number Locator
re lights on..timer counts down but microwave doesn't work..
t checked the hinges and do not see anything wrong. The model is ZMC1090WV001 Really appreciate your help!
Hello. You will need to test the door switches, not check the hinges. Here is what the part looks like. Also, make sure the switch holder is working properly on the unit. Hope this helps. Part number: AP2024337
Re:confused: really appreciate your help...can you tell me where the door switch is located?
Microwave Repair
