Raikar
#1 Posted : Thursday, October 27, 2011 9:19:51 AM(UTC)
Raikar
This is gas double oven range. I have a two issues :
Problem #1 : At times when I start the burner the clock resets. I have found that just when the sparks ignite the gas the clocks resets. I called the Sears Tech but they cannot tell me why it happens. An of course if never happens when they try it.
Problem #2 : The top black cap (which cover the range display and glass) seems to bubble up and sag. I have called in the Sears Tech and replaced the cap 4-5 times now. All they tell me is that it is a cosmetic problem and nothing can be done.
Any body have any suggestions on what could be the problem. I have had this range for less than 9 months. Cap has been replaced 5 times. Clock problem started about 45 days ago.
I appreciate your time to respond and help with any suggestions
Raikar attached the following image(s):
Lmspedersen
#2 Posted : Sunday, October 26, 2014 1:57:14 PM(UTC)
Lmspedersen
Have you received any advice on your clock resetting problem? Our stove started doing the same thing a few days ago.
