Minnie
#1 Posted : Wednesday, January 14, 2009 10:14:04 AM(UTC)
Minnie
I have to place extreme weight on the lid in order for the cycle to start. I think it might be the lid latch, however, I am unable to locate the latch. I downloaded a parts picture and it does not look like my washer. The only thing visible when I open the lid, is the soap dispenser. Please advise
libertyappl
#2 Posted : Wednesday, January 14, 2009 2:55:15 PM(UTC)
libertyappl
Here's the parts breakdown Model LSQ9550PW2, the lid switch is # 11 on page 7.
Nat
kayakcrzy
#3 Posted : Thursday, January 15, 2009 5:01:54 AM(UTC)
kayakcrzy
It sounds like the lid switch is not making contact. Your lid switch on the back left hand corner, sometimes the metal rod, that slides into the lid switch assembly gets bent. If you were to unplug the washer, and open the lid, and stick your arm in the back left hand corner, you will feel and thin metal rod. What you need to do is hold the lid open, and push hard on the metal rod towards the back, and then close the lid, and give it a try. I find 95% of the times the switch is good, but the arm is bent. Give it a try, and save some money. Tom
Minnie
#4 Posted : Thursday, January 15, 2009 5:13:08 AM(UTC)
Minnie
Thank You So Much
washer lid latch stays locked (Oven Repair (including Ranges and Cooktops))
by 5star2168 10/29/2020 5:45:36 AM(UTC)
lid latch or control board (Washer Repair)
by djones3158 2/1/2017 9:56:59 AM(UTC)
Lid latch / right part no. / does not fit (Washer Repair)
by Gene murphy 1/10/2016 12:58:13 PM(UTC)
lid latch (Washer Repair)
by pmuir 12/2/2013 9:29:24 AM(UTC)
whirlpool cabiro lid latch (Washer Repair)
by fastmax 6/23/2010 12:18:20 PM(UTC)
Lid latch switch replaced still shows "L" fault code (Washer Repair)
by Cinco de Juan 9/30/2009 10:25:00 AM(UTC)
