Dishwasher lets in some water then quits the timer will keep running, error shows C6 PO 2, wuold this be the control panel ?
Originally Posted by: ltengel Dishwasher lets in some water then quits the timer will keep running, error shows C6 PO 2, wuold this be the control panel ? I also got that C6 PO error code. Pump seems to work fine. Inlet valve not clogged (I took it apart and checked). Dishwasher still won't run. Do you ever resolve your problem?
