When I put on the dishwasher and press the normal cycle the button blinks. Then I press the cancel button it runs a few seconds then stops but the normal button stills blicks. One time the cancel button ran awhile about a few minutes and cleared the blicking lights. But the normal cycle ran for a long time but only in the washing cycle. I had to turn it off. Theproblem is the blicking lights and will not run properly. Thanks for your help, and I would like a wiring diagram on this machine.
:) Originally Posted by: Linda Cardinale  When I put on the dishwasher and press the normal cycle the button blinks. Then I press the cancel button it runs a few seconds then stops but the normal button stills blicks. One time the cancel button ran awhile about a few minutes and cleared the blicking lights. But the normal cycle ran for a long time but only in the washing cycle. I had to turn it off. Theproblem is the blicking lights and will not run properly. Thanks for your help, and I would like a wiring diagram on this machine. I appreciate the help from you, have a nice day, Linda
Originally Posted by: Linda Cardinale  When I put on the dishwasher and press the normal cycle the button blinks. Then I press the cancel button it runs a few seconds then stops but the normal button stills blicks. One time the cancel button ran awhile about a few minutes and cleared the blicking lights. But the normal cycle ran for a long time but only in the washing cycle. I had to turn it off. Theproblem is the blicking lights and will not run properly. Thanks for your help, and I would like a wiring diagram on this machine would appreciate if you have one or could inform me where to get one.
