2 Pages12>
easyonce53
#1 Posted : Tuesday, January 13, 2009 5:10:08 AM(UTC)
easyonce53
My refrigerator is not dispensing ice or water however, ice is still being made. The green light will come on when you press crushed, cubed, water, etc. but will go out when the lever is touched. It is not making any noise to even indicate that it is trying to work. Any help, or suggestions wold help.
#2 Posted : Tuesday, January 13, 2009 7:47:14 PM(UTC)
Does the dispenser light dim and/or flicker when the lever depressed?
If it does then the problem is a bad main control board.
- The part number for the main control board is AP3950129
easyonce53
#3 Posted : Wednesday, January 14, 2009 10:51:21 AM(UTC)
easyonce53
The light does go off when the lever is pushed. Do you know a site I can go to to get instructions on fixing it mtself?
easyonce53
#4 Posted : Wednesday, January 14, 2009 1:32:58 PM(UTC)
easyonce53
Gene, I followed a link in a preveious message you had sent to someone else and found the information I was looking for. I bought a new control board, installed it and it works great. Thank you for all your help, you've been great!! Again, thank you!!
#5 Posted : Wednesday, January 14, 2009 6:53:26 PM(UTC)
You are welcome. I'm glad you were able to fix it.
democruhcy
#6 Posted : Thursday, December 17, 2009 9:17:38 AM(UTC)
democruhcy
Hello Gene,
I'm new to the forum. I'm stoked to have found it. I'm having the same problem as easyonce53. My model number is PSC23MSTESS. Would I order the same control board? Thanks for your help. Oh could you direct me to the link on how to replace the board?
#7 Posted : Monday, December 21, 2009 5:18:38 PM(UTC)
Originally Posted by: democruhcy Go to Quoted Post
Hello Gene,
Sorry for the delay.
The same problem with very similar refrigerator means the same solution should fix it.:)
The main control board is located on the back of the refrigerator and the new part comes with the complete installation instructions.
- The main control board Part number: AP4436216
djburns2
#8 Posted : Friday, February 11, 2011 11:15:15 AM(UTC)
djburns2
Gene,
I am trying to help a friend fix her refrigerator with almost identical problems as the other posters. Ice maker produces ice OK. Dispenser for water and ice do not work. When pushing either lever for ice or water the light goes out and the control panel inside the refrigerator door (right side) defaults to error. She has a [FONT=&quot]GE Profile side by side MODEL PSS26NGSC BB. Serial number VH403184[/FONT]. I would like to order the main board but wanted to make sure that this would correct the problem. Any help you could give us would be greatly aprreciated.
David
#9 Posted : Friday, February 11, 2011 5:01:45 PM(UTC)
David,
Very likely the new control board will fix this problem and, if you will order it from Appliance Parts Pros, then you have nothing to loose because you can return it even if it was installed.
djburns2
#10 Posted : Friday, February 25, 2011 6:25:59 PM(UTC)
djburns2
Gene,
Ordered the part and it fixed the problem. Thanks! I was wondering...did they change anything on the board to make it last longer? My friends refirgerator was only 3 years old when the part failed.
2 Pages12>
