robertee
#1 Posted : Monday, October 24, 2011 5:56:11 AM(UTC)
robertee
Maytag cennntianal washer water will not enter the washer, checked the filters and checked water flow , it will spin and do other things
sidfink43
#2 Posted : Wednesday, October 26, 2011 5:08:34 PM(UTC)
sidfink43
Check to see if current is getting to the valves when it calls for it. If not the water level switch or the control unit is likely the problem.
If you need more help please post a model number.
