alex_z
#1 Posted : Tuesday, January 13, 2009 4:18:59 PM(UTC)
alex_z
The fron panel (bezel) on my oven occasionally was damaged (but clock itself works fine). I need to replace it but could not find a part. Could you help me in finding manufacturer/distributor/store name where I could buy it?
Thank you
libertyappl
#2 Posted : Wednesday, January 14, 2009 6:03:03 AM(UTC)
libertyappl
Here's the parts breakdown on your unit, you should be able to order from this link.
Model 31213WAM
Nat
alex_z
#3 Posted : Wednesday, January 14, 2009 1:51:32 PM(UTC)
alex_z
Unfortunately there is no such part on this link. There is clock assembly (I have told that my clock works well). I need to replace only clock bezel and there is no such part on suggested link. To my understanding it should be very common think (plastic front of the clock very easy to damage) but I could not find it somewhere. Could you help me?
Thank you
Alex
libertyappl
#4 Posted : Wednesday, January 14, 2009 2:42:35 PM(UTC)
libertyappl
It appears to be part of the clock itself, look at this link of the clock(WHITE) Model 31213WAM
Nat
alex_z
#5 Posted : Wednesday, January 14, 2009 3:50:01 PM(UTC)
alex_z
Nat
Thank you for your advice. Unfortunately it looks like that the bezel is not separate part. I called to online part store and they said me that this part could not be sold separately but only in assembly with clock (manufacturer considers it as single unit).
Do you have any ideas what is the other way to restore clock front panel/bezel on this unit?
Thank you
Alex
libertyappl
#6 Posted : Wednesday, January 14, 2009 7:04:45 PM(UTC)
libertyappl
Sorry replacing the part is the only option I know of.
Nat
