HELP ME GENE PLEASE!!!! FAN WORKS,BUT COMPRESSOR DOES NOT,ITS ONLY 5 1/2 YEARS OLD! HAD A RETIRED SEARS REPAIRMAN LOOK AT IT AND SAID COMPRESSOR IS OK HAS 120 VOLTS AND HAS NO CLICKING NOISE OPENED BACK PANEL AND IT SMELLED LIKE SOMETHING BURNT ON THE MOTHERBOARD BUT NOT A 100 PERCENT SURE IT IS THE PROBLEM,CAN YOU,OR ANYONE ELSE HELP ME PLEASE. THANKS.:confused:
if there is 120 volts to compressor +relay is ok compressor should run , or should be hot, are you sure there is 120 to relay? i have a feeling it is board problem
Thank You Misterfixall,i Feel Better With Second Opinion,good Advice.CAN YOU GIVE ME MOTHERBOARD PART NUMBER AND BEST SITE TO FIND IT? THANKS AGAIN.
