My maytag washer is leaking from the edge of the outer tub. Im a little confused on what i should order,because i cant find a part called mounting stem seal,or is that the same as tub bearing seal?
I'm afraid I did not get it clear. Can you use a drawing reference numbers from the break down diagrams for the Maytag washer Model MAV7600AWW ? Gene.
