This washing machine was in my apt when I bought it 9 years ago. It recently started leaking during every load and more and more water has been leaking as I use it. Is it worth fixing or should I just buy a new one?
I cannot get your model number to come up, but this looks like a direct drive Whirlpool. Take off the cabinet, start it up and you should see where it is leaking. The pump may be the problem, which is an easy repair as are the hoses leading from the tub to the pump and then out to the drain.
