fridgedrip
#1 Posted : Wednesday, October 19, 2011 9:52:14 AM(UTC)
fridgedrip
I have a KitchenAid refrigerator KSRB25FKSS03
My water dispenser drips after it dispenses water. ice maker works, however cubes stuck together in the bin (due to some melting or maybe the leak?).
Was told I should replace water valve. Don't know what part to order. AP3160649 is kit with tubing etc. and part AP3103466 is also a water valve with less pieces. Which one do I need??
Joe / APP Team
#2 Posted : Wednesday, October 19, 2011 11:52:52 AM(UTC)
Joe / APP Team
Fridge, You need to install the proper fill valve,
Part number: AP3160649
If you haven't yet, you also need to consider a new water filter,
Part number: [AP3182816
If it is restricted, it can drop the water pressure and cause the dispenser to drip as well, just remember to flush the dispenser 2 to 3 qts. of water to flush the filter and any air in the system.
Thanks and Good Luck,
