KathyP
#1 Posted : Tuesday, October 18, 2011 1:51:12 PM(UTC)
KathyP
This is a manual defrost freezer, that has begun frosting up very quickly - with frost layers forming within a day or two of defrost. In addition, when I defrost, the gasket around the door leaks water for hours. I don't remember this happening when the freezer was newer. I wonder if a new door gasket is in order or if this could be something else?
KathyP
#2 Posted : Tuesday, October 18, 2011 2:45:19 PM(UTC)
KathyP
Just now I heard ice falling inside the door - which would be the source of the leaking water. Same question, but I wonder if I may need a new seal AND some door parts?
Thanks in advance for any suggestions. The door seal is expensive enough that I would like to be pretty sure I need it before making that purchase!;)
