AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
freezer freezing...refrigerator not cold..no warter or ice comeing out of door.
first..water stopped coming out of door ...then ice ...then refrig went warm...than freezer went warm. i changed the relay/capacitor....now freezer works..nothing else... all lights , buttons work...as well as alarms.. help.....still makes no ice ,refrig still warm, no water or ice coming out of door
Open the frezer door, and see if you hear the fan running in the freezer. Also look inside the back of the freezer, close to the bottom, and see if there is a frost build-up. If so, you could have a defrost problem. Tom ApplianceEducator.com
no frost,do hear a buzzing sound....i shut it off all night ,repluged it in ,inthe morn....went to work ...came home ,still the same..
the fan in the back is running , but not one inside freezer ,i think ..doesnt sound like it anyway.still no frost in freezer,still no water or ice coming out of the door.and not making any ice either.anyway to hook up tester to cheek things out..or do you think it CAN be the fan..tying one more time before i call a repair man out ...thank you..C.B....temp alarm keeps going off,for fridge,all lights and other stuff still working...except water & ice...once again thank you...
will try that ...thanks ...will let you know how it turns out ....thanks again...!!! oh will that stop the icemaker from working ,its up top in the door,and water from come out ,drinking,of the door too ???
THIS FORUM IS DEAD!!!!!!! |
