drum turns but dryer will not heat
The first thing you want to do is flip your dryer breaker off and on a few times, to be sure it did not partially trip. If not it will either be the element or the thermal fuse, that is mounted on the top of the element housing. You can easily access the parts from the rear, with the dryer unplugged. Tom
