CBernard
#1 Posted : Saturday, October 15, 2011 9:19:40 AM(UTC)
CBernard
The fill/drain hose coupling will not stay attached under pressure. I have ensured that the faucet aerator is correct and allows for enough room for the coupling quick-disconnect.
The white gasket? inside the coupling came out, but I was able to reinsert it. It does look as if a piece is missing though.
So, my question is: can I replace just the coupling or do I have to replace the whole hose assembly?
If I must replace the hose assembly, where can I find instructions for accessing the hose hookups on the dishwasher?
Also, are there any cheaper options that I have not considered?
Thank you,
CBernard
#2 Posted : Sunday, October 16, 2011 4:10:34 AM(UTC)
Replacement parts for MAYTAG MDC4650AWW0 PORTABLE DISHWASHER | AppliancePartsPros.com
Looks like you have to replace the entire hose/hookup (Item 3 in Section 7).
Click on it's picture for more views/info.
The following should help with the install.
http://appliancedigest.c...ishwasher-service-manual
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
