Our refrigerator has started to freeze the food, is it due to a bad thermostat??
Measure the freezer temperature and post.
Originally Posted by: richappy ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Measure the freezer temperature and post. The freezer temp is 10 degrees.
Asumming the fridg is running constantly, the freezer should be a bit colder. Check the evaporator coils, should be entirely covered with a light frost. Also, check the condenser and condenser motor in the back
