cglover54
#1 Posted : Friday, October 14, 2011 11:18:28 AM(UTC)
cglover54
I'm not sure of the age of this machine.
I removed the inner basket because it rusted and broke loose almost 3/4 the way around the part of the inner tub that wraps around the shaft.
I think the name of the part that I may need along with the inner tub is the tub support (basket spin tube). Directly underneath this is the rubber gasket that is attached to the outer tub. It isn't smooth and has a lot of rust built up on it. I wonder if I could get away with leaving it and putting the new inner tub on until whatever may happen.
Could you please help me..
tks.:confused:
Joe / APP Team
#2 Posted : Friday, October 14, 2011 11:46:55 AM(UTC)
Joe / APP Team
tks.:confused:
Cindy,
As long as the two square tabs on the top of the spin tube, under the drive block
Part number: AP3114270
Part number: AP2905773
Are not damaged or distorted to bad, as long as there is no leak, and you're careful. You should be fine with a new spin basket
Part number: AP5178685
Drive block and nut
Part number: AP2913937
Heres the part number for the spanner wrench you should use,
Part number: AP4503397
Good Luck and Thanks,
cglover54
#3 Posted : Friday, October 14, 2011 1:17:54 PM(UTC)
cglover54
Tks a Lot!
I ordered the wrench from you and received it yesterday....tks again..
Joe / APP Team
#4 Posted : Friday, October 14, 2011 1:21:55 PM(UTC)
Joe / APP Team
Tks a Lot!
Cindy,
Great, it'll make things a lot easier to work with.
Just be careful, and you'll do fine.
Let us know how it turns out.
cindyinlexington (Dryer Repair)
by cindyinlexington 10/3/2010 7:45:03 AM(UTC)
Cindy (Refrigerator & Freezer Repair)
by Cindy Townsend 1/28/2010 3:46:03 AM(UTC)
cindy (Washer Repair)
by cindy holliday 12/16/2009 5:15:57 AM(UTC)
