sharff
#1 Posted : Thursday, October 13, 2011 9:05:53 AM(UTC)
sharff
Our Kitchen Aid dishwasher started a probelm with the Normal Wash led blinking. After a week or so and repeated tries it started working correctly.
Problem is now back after not using the dishwasher for about 3 months.
Normal Wash LED blinks, hitting Clear stops it.
Rinse LED is always on very dim.
Hitting "4 hour delay" and then Normal Wash and then Start, lights all 3 leds and then turning off the 4 hour delay starts the wash but it stops after about 30 seconds.
Then hitting Clear restarts the wash but it stops after 30 seconds. hitting Clear will repeat the 30 second run
Does anyone have suggestions? Can anyone send the link to the proper service page so I can get the correct sequences of button pushes to clear the memory (before I start replacing parts - growl)?
Thanks,
Al
Joe / APP Team
#2 Posted : Thursday, October 13, 2011 1:43:49 PM(UTC)
Joe / APP Team
Thanks,
Al
Al,
Here is the control reset sequence for your dishwasher:
SERVICE DIAGNOSTICS CYCLE NOTES
NOTE 1.
To invoke the Diagnostics Cycle, perform
the following key presses or actions in less than
6 seconds while in standby:
Heated Dry
➙ Normal ➙ Heated Dry ➙ Normal
And here's an explanation of your issue:
PROBLEM: Won’t Run and LED Above Key(s) is Flashing Rapidly :
Short circuit(s) in keypad or in control’s input lines that read the keys.
Heres the part number for the control panel/keypad assembly:
Part number: AP4261639
Thanks and Good Luck,
sharff
#3 Posted : Thursday, October 20, 2011 7:05:29 AM(UTC)
sharff
I did replace the button / key panel and the dishwasher is working fine.
thanks for the help
Joe / APP Team
#4 Posted : Thursday, October 20, 2011 8:41:07 AM(UTC)
Joe / APP Team
thanks for the help
Sharff,
Thanks for the update, Glad everything is working and you're satisfied.
It was our pleasure to assist you, keep us in mind, should you need help again.
Thanks,
:D :D :D
