robertj1
#1 Posted : Thursday, October 13, 2011 6:51:51 AM(UTC)
robertj1
Disherwasher fills lights go out and does not start
magician59
#2 Posted : Thursday, October 13, 2011 9:03:27 AM(UTC)
magician59
It sounds like you may have a bad circuit board.
Part number: AP4113789
robertj1
#3 Posted : Thursday, October 13, 2011 9:34:41 AM(UTC)
robertj1
Just a little more back ground. The water fills, heats up, it does not progress beyond that. Then lights go out. It did this about 2 months ago then started working fine until last night. Could the float switch be bad? What about the heat sensor? How can I check these and where are they located. I would like to be sure if I am going to spend 150 on a board.
magician59
#4 Posted : Thursday, October 13, 2011 10:06:29 AM(UTC)
magician59
The float switch just controls the power to the water inlet valve; It cuts the power to the valve in an overfill situation. The fact that water comes in and heats indicates that power is getting to the circuit board; this means also that the door switches are doing their job.
Check all the electrical connections, beginning at the main hook-up under the machine. Make sure there are no loose connections, especially with the neutral and the ground wires. A loose neutral or ground can present some pretty tricky symptoms sometimes.
Check the electrical connections at the circuit board. You might even try GENTLY cleaning the end of the ribbon connector from the touch pad, using a clean pencil eraser.
If you don't get a good response from all this, I would replace the board.
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
