2 Pages<12
bthlonewolf
#11 Posted : Monday, September 14, 2009 6:00:46 AM(UTC)
bthlonewolf
Richappy -- thanks! Could I ask you to clarify?
I see the 3 pin connector on the motherboard (which you can see in the top pict above, bottom right), and 2 of those are marked Line and Compressor. The middle one is marked DEFR (defrost?). Should I jumper these two Line/Compressor? Do I then leave the power connector on the board unplugged or do I plug it back in?
I considered making a hookup directly to the 3 pins on the compressor, but I'm up for whichever is easier.
#12 Posted : Monday, September 14, 2009 8:33:54 AM(UTC)
Just leave the power connector unplugged, then plug in the fridg. You can monitor the compresser current through this jumper.
bthlonewolf
#13 Posted : Monday, September 14, 2009 2:55:37 PM(UTC)
bthlonewolf
OK -- going to try this when I get home later but I looked at it briefly on my way past -- the way the connector is (some kind of molex looking connector) is very tight ... I guess I can remove the connectors from the plastic housing and jumper there, not sure how else I can get a good connection... I'll post back later. Thx!
bthlonewolf
#14 Posted : Tuesday, September 15, 2009 7:32:49 AM(UTC)
bthlonewolf
I jumped the comp/line pins, plugged it in, and the compressor started right up, no out of the ordinary sounds or anything.
It's a good bet that the problem is just with the board -- I wish I could desolder and put in a new relay, but the board looks quite toasted in that section and doesn't look salvageable. I'll post back what happens w/ the board...
marz7142
#15 Posted : Thursday, October 13, 2011 3:43:33 AM(UTC)
marz7142
I have the same model, same problem, same burnt relay on solder side of motherboard. What was the problem??? thanx.
#16 Posted : Thursday, October 13, 2011 7:46:28 AM(UTC)
The original problem, the manufacturer did not wave solder the board properly and the thin solder at the power relay acted as a fuse and blew open. Usually, re-soldering will fix it, no relay replacement necessary.
refrigerator repair question (Refrigerator & Freezer Repair)
by tlavacque 8/31/2013 10:25:56 AM(UTC)
Refrigerator Repair Question (Refrigerator & Freezer Repair)
by allantag 8/24/2012 10:17:04 AM(UTC)
GE Refrigerator Repair Question (Refrigerator & Freezer Repair)
by jgolfaholic 5/17/2011 7:59:47 PM(UTC)
2 Pages<12
