Hello, My Kenmore Dryer Model 110.82824102 no heat. I have tested the below items. Heater coil "Good" Thermal cut-off "Good" High limit thermostat "Good" Thermal Fuse "Good"
I trace the problem back to the Control Board heater relay. The relay dose not turn on when the Dryer is running. Is their other testing to Control Board I can do? Thanks Stu
Here are your parts Replacement parts for KENMORE 11082824102 | AppliancePartsPros.comSee the attachment for the tech sheet. Check the thermistor. How do you know the heater relay is not closing? Have you checked the power to the unit? Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker. The heating coil requires the full 240 volts. If this does nothing, check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. Be careful as 240 volts is lethal !!! |
THIS FORUM IS DEAD!!!!!!! |
This is a note "What fixed the problem" I got a new controller board PN:8557308 and pluged it in. Now the Dryer works. Thanks for all your help. Stu
