I am having a hard time removing the connectors from the handle switches and the control board.
Originally Posted by: jesser  I am having a hard time removing the connectors from the handle switches and the control board. Jesser, Someimes, the connectors can be difficult to remove, most people use a small flat blade screwdriver or pair of needle nose pliers, to pry the connectors and terminals off the switches and board connections. Good Luck, :) :) :)
Good Luck, :) :) :) I replaced the handle asm, front panel, and board. Now I can choose the cycle length (Heavy/Normal/Light) and when I do the heated dry and rinse only light up. The start and delay start will not work.
Originally Posted by: jesser  I replaced the handle asm, front panel, and board. Now I can choose the cycle length (Heavy/Normal/Light) and when I do the heated dry and rinse only light up. The start and delay start will not work. Jesser, You need to recheck the touchpad/control panel ribbon, Make sure all the tracers in the ribbon are a solid line from end to end, The ribbon is not creased, cracked or twisted, check the connector pins on the control board and ribbon make sure theres nothing breaking the pin contacts. As I understand it, you've replaced the door latch/handle, control board, and control panel, Thats the whole control system, If your issue persists, order and replace the control panel assembly, Part number: AP4364306
Thats where the issue would be. :) :) :)
