yupper18
#1 Posted : Wednesday, November 7, 2007 10:52:15 AM(UTC)
yupper18
The dryer will not stop running, I replaced the timer but the same problem is occuring? Help John
#2 Posted : Wednesday, November 7, 2007 11:27:22 AM(UTC)
Hi John
Did it start without pushing the start button?
How does it dry?
yupper18
#3 Posted : Wednesday, November 7, 2007 7:32:47 PM(UTC)
yupper18
No it will not run without pushing the start button. It dry's the cloth's fine but once the cycle is finished it will not shut off.
#4 Posted : Wednesday, November 7, 2007 8:19:18 PM(UTC)
Did the timer move to the off position by itself or it skipped the off position and kept running? Did the timer move at all?
yupper18
#5 Posted : Thursday, November 8, 2007 6:54:07 AM(UTC)
yupper18
I'am wrong when you close the dryer door it will start up on it's own, also the timer does function properly. John
#6 Posted : Friday, November 9, 2007 12:30:52 PM(UTC)
In such case no doubt the problem is the shorted start switch which has to be replaced.
- The part number for the start switch AP2975301
Good luck.
Odd Kenmore Dryer Model number (Dryer Repair)
by adamm53 3/2/2024 3:42:02 PM(UTC)
Kenmore Dryer blowing thermal fuses (Dryer Repair)
by Marius 11/21/2023 2:26:28 PM(UTC)
Kenmore Dryer stops running after start button is released (Dryer Repair)
by Jbee14 7/30/2023 11:15:53 AM(UTC)
Kenmore Dryer spinning cold air nonstop until the door is open (Dryer Repair)
by Guest 5/15/2023 10:22:27 AM(UTC)
Kenmore Dryer, Help! (Dryer Repair)
by C DeBardeleben 4/18/2023 3:58:41 PM(UTC)
Kenmore dryer issue when heat is on (Dryer Repair)
by Guest 2/2/2023 2:17:08 PM(UTC)
Kenmore Dryer Model:86984110 (Dryer Repair)
by CarolynC143 10/23/2022 5:00:36 AM(UTC)
Kenmore dryer help Elite HE3 (Dryer Repair)
by Guest 5/5/2022 8:17:09 PM(UTC)
Repair manual for Kenmore dryer model 110.85081401 (Washer Repair)
by Guest 5/5/2022 2:29:52 PM(UTC)
kenmore dryer wiring (General Talk)
by epyveras 3/24/2022 7:04:26 AM(UTC)
KENMORE DRYER WIRING 796.813 (Dryer Repair)
by Guest 3/24/2022 7:00:58 AM(UTC)
Kenmore Dryer Model 110.76752500 Parts (Dryer Repair)
by redknitter 2/23/2022 7:24:03 AM(UTC)
kenmore dryer powers up with lights on, push start and it chirps and that is all (Dryer Repair)
by Guest 10/14/2021 7:53:03 PM(UTC)
Kenmore Dryer 41790052990 (Dryer Repair)
by Guest 3/26/2021 4:59:53 PM(UTC)
Kenmore Dryer Timer Power Resistor Rating (Dryer Repair)
by mhall264 3/19/2021 9:04:39 AM(UTC)
