My Ice dispeser stays on until the freezer door is opened. I took the ice/water asm out of the door and unplugged the brown wire from the despenser for now. I had ice MAKER problems during this and have it fixed thanks to this forum (thanks for your time answering post). I don't think the despenser and maker problems are linked....but then again I am not a repair man:D Any ideas on what I could check/replace ? Thanks in advance
"BUMP"-anyone even have a posibility ? I have looked all over the net and the only problen I ever see is the despenser NOT working. I have not found one other person with my problem. I am willing to try/replace anything that might even fix it. I just don't have a manual (and can't find one to download) to even look at to see what I could replace logical. I have to wonder about the circuit board, but there is no visible defects(burns etc) in it either. I had it all apart and on the kitchen table and inspected all parts/switches and everything looks good to me.
Does anyone know why the Kitchen Aid ice despenser want despense Ice. The Ice maker works makes ice but will not despense through the door. IT makes a clicking noise when I try to get ice out.
Originally Posted by: martinteda  Does anyone know why the Kitchen Aid ice despenser want despense Ice. The Ice maker works makes ice but will not despense through the door. IT makes a clicking noise when I try to get ice out. Would like to suggest, you start your own thread in the Refrigerator Repair section, using Post New Topic button. Post detailed description on the problem as well as the complete model number of the refrigerator. People will then see it is someone with a problem. This should increase your odds of getting a relevant reply. Gene.
