2 Pages<12
carlous
#11 Posted : Monday, August 11, 2008 12:06:30 PM(UTC)
carlous
I'm still waiting on a reply from my last thread.:mad:
harryb69
#12 Posted : Tuesday, August 12, 2008 8:25:36 AM(UTC)
harryb69
It wonot drain water after it rinse?
#13 Posted : Tuesday, August 12, 2008 12:58:30 PM(UTC)
These two switches on the lid switch assembly should be properly adjusted so when one of them is "open" the other one is "closed".
carlous,
Did you see this reply?
carlous
#14 Posted : Tuesday, August 12, 2008 1:24:00 PM(UTC)
carlous
I got the switdhes adjusted. The washer now spins but won't fill up. Before it would fill but nothing else.
#15 Posted : Tuesday, August 12, 2008 2:36:26 PM(UTC)
Make sure both water shut off valves are open, the lid is closed and both lid switches are properly engaged.
Check for 120VAC to the water inlet valve solenoids. Use the wiring diagram for the proper diagnostics.
joejoe77
#16 Posted : Saturday, October 8, 2011 7:31:51 PM(UTC)
joejoe77
roper 8525148 whirlpool super capacity 7 cycle 8525148a washing machine
judas.. sock in pump!
was gonna work on kitchen lights .. so turned off fuses...opp i turned off washer/dryer.
so turned it back on..went to turn on dryer/washer
found washer drained and spinned .. hmm..
was able to turn dial and she started fillin so walked away .. oh well i thought.
came back she was full.
started playing with dial.
she would only humm... and not spin or agitatate or drain.. thought maybe a dial gaget prob.
other mentioned may be a lid fuse or connector thingy
judas!
even when i put my hand in .. I could not spin the big thingy.
then i started thinking motor ceased...
I just kept playing with dial .. filling/ drainin with bucket .. and she kicked in for a sec.
then the spinny thing inside freely moved.
tried to carry on.. and boom .. still hum.. moved an inch and centre thing locked again.
ahhhh
so there I go takin off the back .. breakin plasit clips etc.
All I had to do was tip machine on its back
and a hose went in and another hose went out of this white disk.
Unclipped white disk
pulled off hoses
looked inside disk..and there was a little baby sock wrapper around a plastic flywheel inside beige circlar thingy right on bottom of washer.
puller er out. she work perfect.
cept for all the plastic stuff I ruined pulling the back off it..
ahhh..one of those middle / back plastic things held the water filler thingy..
Guest (5)
2 Pages<12
