heitl
#1 Posted : Saturday, January 5, 2008 8:25:06 AM(UTC)
heitl
My microwave looks, smells, and sounds normal but it wont heat. If i set the power to 50% i hear it hum and turn off but no heat. I checked the resistance of the capacitor and magnetron which were within spec. The diode however appears to open in both directions. It does not appear damaged in any way. Would a bad diode cause these symptoms
thanks
eyefish
#2 Posted : Thursday, January 8, 2009 1:16:53 PM(UTC)
eyefish
Replace the Magnetron!
I just did this morning (same unit exactly as yours with identical symptoms!)
And you must test the diode with a 6-12V battery to get the correct results....forget about using an ohm meter to test it.
If the diode is good, replace the magnetron.
Amana microwave will not heat (Microwave Repair)
by ckiley 2/1/2013 11:51:23 AM(UTC)
