AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Help confirming part number for KitchenAid dishwasher
Hi, I'm pretty sure it's the control panel--lights go on as they should but then it doesn't start.
Having trouble figuring out if AP3775964 is the right part. thanks
Are any of lights blinking? The part number you posted is for the control board. The control panel Part number: AP3177369
Hi, the lights go on as they're supposed to. You hit the cycle button and the dry and the "start". They all light as usual and then....nothing happens.
Check the door switch and make sure it's engaged properly when the door is locked.
What's the next option? Control panel? thank you! Originally Posted by: Gene  Check the door switch and make sure it's engaged properly when the door is locked.
Originally Posted by: soundtownsal  What's the next option? Control panel? thank you! Yes, it is. Gene.
thank you very much! Originally Posted by: Gene  Yes, it is.
Dishwasher Repair
