We used both ovens simultaneously. Now the cooling fan(s) will not stop running. We turned power off at the breaker, but when power is restored, the fans come back on. Both ovens work normally otherwise. We have not self-cleaned the ovens in a year. Do we need to replace the control board? I have been told the part number is 8302967 but cannot find that part number associated with this model oven.
Sounds like the control board has gone bad. Manufacturer part number 8302967 is Appliance Parts Pros part number AP3767567Here are the break down diagrams for the Whirlpool oven Model RBD306PDB12Gene.
