glennd
#1 Posted : Tuesday, January 6, 2009 4:06:48 PM(UTC)
glennd
Aside from removing the dishwasher and setting it up on a test stand, how do I find the leak? There is not alot of viewing from the front. I suspect one of the pumps are leaking but I'd rather be accurate than guess. From what I can see, the water inlet valve and hoses look ok. There is water forming below the circ pump but I can't be 100% sure its the source. Is there a common repair problem with this model? I'm an HVAC tech, so repairs are what I do. Unfortunatly, I have not been able to locate an exploded view of the parts to assist in the diagnoses.
#2 Posted : Wednesday, January 7, 2009 7:26:56 PM(UTC)
You have to remove the dishwasher from the cabinet and remove both side panels to pinpoint the leak. There is no other way to do it.
